Power window motor
bwp116
PA
The rear right window on my 94 completely doesnt work. I hit the button, get no noise or anything. Everything else is fine. Im assuming this is the motor. If anyone can tell me
where i can get a new motor, and how to install the thing that would be great.
nothingtoseehere
Either get a new motor from FORD, or check your boneyards for a used one. Be carefull of used ones though as they may not last long once installed. To get at the motor, take off the door panel and carefully peel back the black weather matting. Once you have located the motor, remove the three hex head bolts and then drill out the rivet using a 1/4" drill bit. Disconnect the harness from the motor and finagle the motor out. Put the new one in and put the three bolts back and put a new rivet in. Very easy process. Make sure you disconnect the battery first though.
