dstig1
Well it looks for sure like I have a PS leak as the fluid level drops enough to make the pump moan every few weeks, and it's getting more frequent.
The rack is only a year old, and there is no sign of it leaking, plus the PS fittings into the rack are bone dry. I know it's probably a hose somewhere, but the pump is so buried, I can't tell if it is the source. The cooler is crudded with some stuff, so it's leaking down that way - either running down the hose or that is the source. I figure the hoses are old, so it probably just pays to do them all.
Question: what is the path of the lines - from where to where to where? Helms manual doesn't really show the whole system. Is it resevoir>pump>high pressure to rack>cooler>resevoir? What's the other fitting on the rack then? I should have looked more at this when I had it all aaprt, but now it's impossible to see anything...
And what is involved here - the rack has fittings on it, but a lot of the rest is just hose, so what do you need to get to replace this stuff?
Thanks,
Thanks,
