Just got my '94 ATX SHO about 2 months ago. Has 90K miles, 1 owner, in very good condition. I washed the back side of the engine with cleaner & then sprayed it off w/water recently & developed a low RPM skip. Yep, a little water got in plug well #4. I cleaned the plug wells out, pulled the Autolite xxxx32PP plugs & found them to be worn a good bit so I installed new Autolite single platinums of the same value (xxxx32P). The old plugs were worn to about .056" but clean. I gapped the new ones to spec (.042") & installed. Skip is gone, runs smoothe, but I've lost 10-15% of my low end power. I have a theory of why the power loss but I'd like you wisdom & experience here. I'll say up front that I haven't seen any documented evidence that double platinums ignite with a hotter spark so I don't believe that is the difference. Why the power loss & how do I fix it?
