Power antenna module location
reedssho
Indiana
I have an 93 mtx and the antenna was working sporatically then now not at all. I read a post about the power antenna module and picked one up to put in, before I took out the power antenna through the wheel. Seemed pretty straight forward it is in the upper right side of the dash behind the glove box. but I dropped the glove box and don't see any relay or module. the picture from the thread is gone. I see a white module at the top and a blue box on the right, is it behind something?- Also anyone found an adapter to just mount a fixed mast into the power antenna bracket? I think a black spiral mast would look better than the power antenna anyway.
Rubix
Remove the front wheel well liner on the passenger side. You'll also need to remove the chrome antenna cover on the fender. If you're replacing the motor it's a breeze, disconnect the wire harness and one small nut. I replaced the mast on mine with an ebay one (thanks kevinspann) in a matter of minutes by just removing the chrome antenna surround and the small nut under that. Then I removed all broken bits of old mast (I ended up pulling the motor out and taking it apart, which might be necessary) then turned the radio on and then off (engaging the antenna) and fed the new antenna in. After an on/off cycle of the radio yet again the alignment was fine.
reedssho
Indiana
but where is the 'power antenna module'
Thanks for the details on replacing the antenna. I still have a power antenna module but I'm not sure if it is the right part. I looks like a regular plug in relay. but when I looked behind the glove box I didn't see anything like it. I couldn't find a poat with a picture. There is a large blue box on the right side and a white one at the top. Could I get a description?
