Power antenna harness
DDakRT
Mississauga, Ont, Canada
Do you guys know the antenna harness than plugs into the gen II radio is the same harness that plugs into the power antenna switch from a gen I?
Huntervf
Bored now
Back in Michigan ... again.
Moved to gen I/II electronics & audio thumb
And yes, I do believe it's the same. Can't say for 100% on it, but working on my 89 & 91 parts car and then working on the 95 I believe they were the same. But I don't have the two side by side to compare so don't quote me just yet :D
RStalveyARFF
too many shos
Georgetown, MA
When I installed the aftermarket radio into my 92, I didn't notice any antenna harness. I hooked used the conversion plugs and had no problems. The blue wire on the head unit properly raises and lowers the antenna on startup/shutdown. shrug
DDakRT
Ahhh yes, audio and electronics, sorry :)
It's not a harness really, just a plug like you said. My new headunit can control the antenna as well, but I want to be able to listen to CDs and not have the antenna go up (lots of wind noise with the sunroof open), and that I can have it up in the winter is water got into the motor and freeze up.
