fred79
I have a possible overheating problem the gauge will run way past normal under heavy stop and go or idling. I have seen the fan come on but alot of the time while it says that the heat is inredably high they aren't on. so I thought the fan wasn't working so I bought a fan control relay with a seperate sensor and the fan still didn't come on. I have already replaced both the temperature sensors and the thermastat twice. usually as long as I am moving it stays under the top of normal but if I stop at a redlight or have to stop and idle, it runs all the way up and takes along time to come down. I thought maybe I had air so i've tried purging the system. I just finished flushing the system and refilled with fresh coolant, and changed the thermostat again. I have also changed the rad cap, so i have changed everything but the radiator, what could possibly cause this I checked oil and found no foaming, and there was no oil in the coolant I removed, so I don;t think its a head gasket.
i used a sorenson sensor could I have bought a bad temp sender?
any ideas?
thanks
any ideas?
thanks
