Possible Heater Core fix?
SASHO91
Zoom Zoom
San Antonio,TX
I was thinking about this awhile back, and since i am getting the car back on the road this weekend, i think im going to need some type of heater....
i have seen the plug in ones, and thats a last resort....
BUT,
my idea was this...
ok, the heater core is basically a radiator, right?? what if i took a bucket, filled it with water, added some of the radiator stop leak stuff (insert brand) and ran it through the heater core only via a buldge(sp?) pump...
only problems i can think of would be the stuff coming loose and going through the system. also, i dont know if that stuff is heat activated or what?? which means i would have to heat the water to fix it.. but when i run coolant through there, im wondering if that would re- "melt" the stuff again....
does anyone know how that stuff works? is it like a JB weld solution?
I feel this would be ALOT easier than pulling the dash out... and if it dosent work, then im only out a few bucks....
I guess if all else fails i could just drop an egg in there.... :nut:
TIA.
greenbeanmtx
King Skidmark
Waco Tx
BUT,
my idea was this...
TIA.
Hey the egg worked on myth busters :p
SASHO91
Zoom Zoom
San Antonio,TX
karson, when i get the car back on the road.... i was thinking about heading up there for a day... that way you could work you magic on the twin... buffing wise...???
whenever is good for you, if you dont mind.... lunch is on me.
greenbeanmtx
King Skidmark
Waco Tx
sounds cool to me but you will need about 12 buffing pads and whenever you decide let me know cuz i dont know where ill be living. I think i already mentioned it but we are building a new house and the one ive spent the last 12 years in is now going on the market. I may be living in a motel6 :p
Oh and according to the instructions on that stuff used it says to only use when 60 or warmer. So we might have to wait a bit. I went to put another coat on mine yesterday and it was around 50 here. The stuff had seperated in the bottle and i kept having to shake it up and it ended up not coming out the way i wanted it to. We'll figure up something. Send me some pics of ur car cuz i didnt think it needed a high speed buffing?
SHO#7
Cincinnati
I do not know how bad your leak is. But I had a slight odor, and used half a can of Alumniseal (sp). Ran the system for a few hours, then I drained an re-filled the coolant to get any loose amounts out ( I hope ). It worked in my case. I did not have any fogging issues, or an actual leak that I could find. Just the smell in the cabin.
Mike
SASHO91
Zoom Zoom
San Antonio,TX
IIRC mine wasnt too bad.... allthough it was about a year ago or so...
I do remember "steam" coming from the defroster... so i think it was on the worse side...
