I have posted on this problem before, but some events have taken place that may help narrow the problem down.
Symptioms:
Car is rough starting..sometimes, and when it is..engine light comes on, tach does not work.
Car suddenly develops the same symptoms while driving..runs rough, bucking, tach does not work CE light comes on.
Symptoms are not constant..car may run fine for days without exhibiting the problem
New information....car seems to be doing this 1) in the rain, 2) after the car has come out of a car wash, or has recently been pressure washed at home...not necessarily right away..maybe 10 - 30 minutes later. Hence I did not make the connection right away.
Is there a "boot" around the CPS input lead that gets cracked or worn, and could water leaking in be causing the problem.....where do I look?
Symptioms:
