cannibinolmasa
i just got my 89 titanium, and it was broke when i got it. i went through the wiring harness on the ecu and icm, and found a fusible link that was blown. so now i got it running, but i swear its possesed. i put a cone filter with a heat shield on it, and it would sputter in a sequence as you drive the same speed down the road.(ex. sputter 3 times every 30 seconds.) i replaced the fuel pump and filters, cleaned out plugs,(needs new valve cover gaskets too) thermostat, and water pump. havent stopped the the problem yet, but i encountered a new problem. i got a steel mesh fulter now, and i can't accelerate too fast or the rpm's rev to 7000 and it won't stop! i have to restart it 2x, and pump ther gas pedal while the car is OFF. then it'll idle again. i don't think my maf sensor likes my new filters (wink wink)
