Positive Crankcase Ventilation system problem please help
oneqwicksho
cleveland, ohio
Just to be sure, the vacuum should come from the TB ******; not the hose that goes down to the oil separator down in the "V" of the engine. No need to clean the oil separator until you take the whole engine apart. Just put a longer hose on the separator and run it down into the air stream under the car. And plug the 90 degree fitting on the TB.
Tom
Yes no vacuum on the ****** at all. And, the hose coming from the oil separator in the "V" of the block is barely pumping
out any smoke like it use to. and, with the motor dis-assembled how do you clean the iol separator? Can you get to it from oil pan side?
Thanks
Off Road SHO
Moderator
Why do you think your oil separator needs cleaning? Because your not getting as much smoke out of it as you were before? The sparator is just a sunken box in the top of the block that is covered with a tin plate with a hose ****** on it. The box is open to the back of the block where the vapor passageway is covered by the aluminum rear main seal holder. The passage up the back is zig-zag so that the vapor has time to condense on the cooler aluminum and drain back into the oil pan.
If you're worried about not getting enough flow through the PCV's path, blow some air into that 1/2" hose (towards the block, not the TB) and see if you get air to come out of the oil filler cap on the valve cover. If you get any air whatsoever, there is nothing wrong with that part of your system.
As far as not having much vacuum at the TB's bottom ******; you wont at idle. It uses Bernouli's principle to create a small vacuum when air is rushing through the TB. It does not use intake vacuum, caused by the piston going down in the cylinder with an intake valve open. Bernoulli's vacuum is caused by air rushing over a hole, whatever is in the hole is sucked (actually, it's pushed) into the stream of rushing air.
Tom
oneqwicksho
cleveland, ohio
I'm just not getting vacuum on the hose off the side of the tb. and, I did have vaccum on that hose before I seafoamed the motor/gas tank. so, I don't know if the seafoam fixed/broke something
And I can blow through the hose going to the oil separator (to the "v") and air will come out the oil cap (with it off) and through the vc hose (with it off)
