Porter or Cone?
Funmart6
my name is mud
Auburn, Alabama
Which yields more HP, porterized intake which utilizes the flat panel air filter and box, or a cone type air filter intake system?
okay eveybody get your opinions ready on which is the best design. :)
MilTownSHO
Horicon, WI
The factory air system setup isn't that bad as far as the SHO goes. It receives cold air as it is. If you add the cone it sounds great, but unless you rig it up right your drawing hot air from the engine bay. There are advantages and disadvantage either way...
Porkchop
The Black Sheep
Virginia
MilTownSHO:
He is right, but the stock setup is restrictive, if you want the best of both worlds, construct a CAI system with the cone filter sitting in the fender area, that way you get rid of the restrictive stock setup, get the volvume change from the cone filter, and the advantages of getting cold air
It is easy to get some 3" expandable semi-rigid aluminum duct. Use about 12" of the duct. Tape it to the air box intake hole using black electrical tape and wrap the entire piece of aluminum then stick it in the fender. Use a K&N panel filter.
Otherwise do this. My Intake
<small>[ April 18, 2003, 10:40 PM: Message edited by: SHOZ123 ]</small>
SHOGHOST
ST. Louis
SHOSHOP.COM has a cone filter cold air box for the Gen III foe about 240. It looks pretty good but it is a little high boink
The SHO Shop kit does not do a good job of keeping the temps down. It is what I had and decided to take some temp readings just prior to the TB. I had temps of 120F and more at times with it. I did insulate and seal it more to get +5F ambient temps there though. Look rather rigged though, ghetto is the term I believe.
In the end I used the SHO Shop supplied air filter and MAF adapter plus about $30 worth of materials to put the filter in the fender.
SHODWN
Mother Threasa
Spencer,Ma usa
Best and cheapiest
Buy the panel filter, take the wheel off and then the inner fender and cut the sax off above the muffler.
Unless you want to do try your own thing, or what Nimz and I have done but cutting out some steel from the upper rail to allow a 3" (full) intake happen.
99V8SHO
GasOilAndTires
Gaithersburg, Maryland
SHODWN:
Best and cheapiest
Hehe. This is exactly what I did. Thanks Kirk!
I have been thinking about getting a cone filter to put in the fender and taking the panel filter out, and maybe one day adding cold-air. but I have heard that these air modifications actually INCREASE 0-60 times. Is this true?? shrug headbang
SHOGHOST:
What did you use to insulate the box? cheers
Aluminum bubble wrap.
Wess
Jarhead
MD
Where can I get a MAF adapter to fit our cars? I've searched and searched, but haven't found one yet.
<small>[ April 21, 2003, 02:28 PM: Message edited by: Wess ]</small>
Look at Mustang sites. One guy I know made one out of a PVC toilet ******. :)
<small>[ April 22, 2003, 12:43 PM: Message edited by: SHOZ123 ]</small>
hess_sho
