I am currently driving my 89 and boy is it making some noise!
First one to start up after installing the STB's, struts, and springs is the vibrating in reverse coming from the rear. After I come to a stop, it's still vibrating until it goes away within 2-3 seconds.
Next, which happened tonight, when I came to a stop on the access road, I hit the brakes pretty good to see how the springs were. Right after that, I turned under the bridge and punch it in 1st gear. I took the revs up to 6k, then I made a 2 second upshift to second gear and went WOT up to 60 mph. When I let off, I started to hear this popping sound that varied with speed. The sound does go away when you turn to the right at any speed or get below 15 mph.
What do yall think?
I got under the SHO[gas station] in an attemp to see if something was vibrating/loose or if the subframe was loose, nothing. So, I kept driving home, about 20 miles, thinking the whole way of what it could be. I then came up with a broken coil.
I wish I would've known and got a chance to look when I was at the gas station, but now I have to wait until tomorrow when the sun comes up.
What do yall think?
