Plug Wire Question
SuperG
Houston, TX
I could sware I saw a post saying that the WR-4033 was good for either the 3.0 or 3.2, but now I just noticed a different part number listed on Shotimes.com for the 3.2 (WRE4081) and now that I am looking, I also see it on FordPartsNetwork.com.
Can you guys verify this?
HopefulSHO
Bellevue, NE
'Tis True. The 3.2 does have a separate set of wires, but the 3.0 wires will apparantly fit with just a little bit of routing, and are much cheaper.
No special routing required. Just make sure you get the wires straight from loom to loom and from the rear bank to the coil pack. They fit fine and have the cylinder number printed on the wires where the 3.2L wires do not.
SuperG
Houston, TX
I haven't really looked in detail yet, but the little harnesses (is that what you are calling looms?) seem to be a tight fit where the wires are held from touching the engine...do they snap apart in order to get the wires in or will I have to remove the mounting brackets to get at them?
I should probably ask this question while I am near my car, rather than while I am in my office...Thanks for the help, I cannot wait until the wires get here...
