Please READ! Please HELP
Jesse
ohio
PLEASE READ THIS AND HELP ME OUT. Cause i dont wanna send her (91 ford tarus sho) to the scrapper thats my only other option my parents are giving me. I love my car as if it were family.
Hello i hope you remember the problem i was having. I will refresh you. I was driving down the road and it felt like the engine was losing power! a couple seconds later it died on me well it sat for a while before i did a little work on it. I checked the spark plugs and they were filled with oil so i got new wires and plugs.
Before it would turn over but not start sounded crappy well after i did this it sounded a little better. But still wouldnt start. I messed with the fuel shut off button in the trunk well i tried it a couple times in the 2 diff positions and it started once and ran for like 2 minutes there was a rattleing noise comming from passenger side of engine loud! Makes me think of like an exuast pipe rattling but its not. I know i had a leak from the heater core but doubt it has anything to do with the noise. Please give me some ideas.
Mr Anonymous
Tire Wall
If you just keep ignoring the valuable suggestions in your other threads and keep posting new "HELP!" threads, that should solve your problems! squint
You've not indicated in any of your other threads if you actually tried any of the suggestions from other members. Presuming you haven't tried them (including simply reading the codes), there's nothing we can do via our PC's to fix you car.
Maybe it's a good time to shell out the $10 to the forum and sell the car to someone who will give it a good home.
Forgive the sarcasm, but we can't help those who can't help themselves! :rolleyes:
Jesse
ohio
i did what they told me exept pull numbers. I cant pull numbers though the ford folks says the car has to be running to get codes cause the computer doesnt store the codes if the battery dies or gets disconnected. So i cant get codes im taking it to a shop but not a ford shop. I just wanna know what might cause that noise. i did put the new plugs and spark plug wires in and they work but the car is having problems like the noise its making and it shakes a little more than usual
SHOtimer
#2910
Santa Clarita, Ca
Can u hear that fuel pump? That could be your problem, bad fuel pump= no gas to engine..and no engine. If you don't hear it whine while you try to start the car that could be your problem.
Doug
Jesse
ohio
i hear it when i first turn the key. Pluss the car did run but sounded like starving for gas maybe. was lound and heard noise by passenger side of engine
