Please Help !!!!!
shoisfast
NM USA
I was having a problem that after the car got hot I would have to take off the gas cap and then it would run after the pressure was released but today it ran fine till I got to my daughters work and then it would not start it was close to a hundred degrees outside but it never showed hot on the gauge .it started about 2 hours later and ran fine anyone have a clue ?
shoisfast
NM USA
I did not notice what the tach was doing at the time but now it is fine as is everything else
Bizzy
Just keep your eye on it. The next time it stalls try to keep that in the back of your mind to look out for.
Also try running your codes, when you get those post them here. That will help give you a clue what's going on and help us to help you more also.
