please help me get my baby running
shomoman
Alright I have a 1994 ford Taurus Sho mtx with 160,000 miles I just recently had the fuel injectors cleaned did all the 60k tune up including plugs and wires valve cover gasket oil change water pump crank and camshaft position sensor before doing all this it would crank but not turn over after will not crank at all but all electronics work it ran before parked for two years please help me I don't know what else to do thanks in advance
TimboSHO
Intermediate
Wyoming, MI
If it doesn't crank, it has to be battery or starter related ( or the connections in between). Need to get that figured out first!
I have a hard time following 3 lines of text all smashed together without punctuation. Let me see if I understand: before you did all the work, it would turn over but not fire. After all the work, it will not even turn over. Is that correct? If so, Timbo has it spot on.
