(PIC)Question about ZEX install
Cocoa,Florida
2cyjf9i
i have read over the instructions,andi just want to make sure i dont screw anything up.
so if i understand correctly the regulator hose connects from the NMU to the upper arrow right?
and the intake hose connects to the NMU and the lower arrow right?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I do believe so. Although I have never run nitrous on my SHO, I do have the kit and after removing the intake tonight, I dont know of any other place that it would go.
*disclaimer* NiNeTy Fo SHO is not held responsible for any blown engines. */disclaimer*
Cocoa,Florida
:lol: :lol: :lol: :lol:
RStalveyARFF
too many shos
Georgetown, MA
yes, you are right. MAKE SURE YOU CLAMP ALL OF THOSE CONNECTIONS, EVEN TO THE INTAKE AND FPR. If not they WILL blow off!
AREA 91
PA SHO SHOP
Area 91
You are right. I also second the hose clamps. I've had it happen more than once.:rofl:
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
ShadetreeSHOguy said:
I wouldnt be proud of that turd if i were you :snicker:
*runs and hides*
Chris, I have a nice project SHO 4 u so you won't have to hide behind that mustang anymore.
Geek SHO
SHO Addict
Rohnert Park, CA
My NMU was mounted behind the driver's side strut tower (in that little pocket back there), so I used vacuum from that little battery of vacuum lines right there as it's source. Ironically I just uncapped a free spot on the vacuum battery, took the small hose off the FPR and hooked the NMU to the battery with it. Then, I took the cap and stuck it on the intake. Actually, you can still see the NMU in my current signature, it's just not in use.
