Perry!!!
1995mtxsho
Grand Rapids, MI
What ever happened with this project you were working on?
Would you mind elaborating on what all is involved and the parts needed?
12 11 04QSLMeet027
12 11 04QSLMeet028
12 11 04QSLMeet029
pjtoledo
'ol man in the SHO
toledo,ohio,usa
I happen to be the world's foremost procrastinator, more discussion on that at a later date.
Ok, long time ago on those pics, I kinda lost interest and never finished the project.
Late 90's Cobra rear rotor, caliper BRACKET, pads. SHO 93+ CALIPER.
Custom made rings to center the rotor, custom made (not really made yet) backing plate. Re-drill the rotors.
I believe that John over in Cleveland had all the parts made, not sure if he put them on his SHO or not.
Perry
1995mtxsho
Grand Rapids, MI
If you still have that setup laying around, I could use a couple measurements of the cobra caliper bracket. like the width of the groove that the rotor spins in, and the measurement from the bracket-to-knuckle hole centerline to the slidepin hole centerline... if that makes any sence. And also if you know the difference between the SHO backing plate bracket holes vs. the cobra backing plate bracket holes you made-up.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
I still have the parts laying around. But, you caught me in the middle of a "being lazy" month so it may be a couple of days until I post some numbers.
The setup uses regular 93-95 rear calipers, the Cobra pads are thinner to fit over the .7" Cobra rotor. The caliper brackets have 93-95 bolt hole spacing for the caliper bolts, and 89-92 spacing for the backing plate holes. The custom backing plate is needed to move the bracket out a bit. I'll post the numbers on how much sometime soon.
Perry
