Im getting ready to start wiring up my festiva / sho project . I have a few questions about PCM wiring. Below is listed what I have so far . A few have question marks next to them. Im not sure of the function , if I need to use it and / or what conditon to jump it in ( open or closed) Feel free to add on or change any thing.
1994 sho MTX based wiring
1 B+ ( battery positive ?)
2 power steering pressure switch ( leave open )
3 VVS ( attach )
4 iginion diaognositc monitor (?)
5 brake on off ( open)
6 VVS- ( attach)
7 ECT -engine coolant temp ( attached)
8 not used
9 MAF return ( attached )
10 a/c clutch ( not using)
11 speed control ( not using )
12 fuel inj ( attached)
13 fuel inj ( attached)
14 fuel inj ( attached)
15 fuel inj ( attached)
16 ign ground ( attached)
17 data link ( ?)
18 octain adj ( ?)
19 fuel pump monitor (?)
20 case ground ( attached)
21 IAC ( attached)
22 low speed fuel pump relay ( attached to ccrm)
23 knock sensor ( attached)
24 ckp ( attached)
25 air charge temp ( attached)
26 referance voltage (?)
27 egr feed back ( not using)
28 speed control command switch ( not using)
29 o2 1 ( attached)
30 clutch pedal ( attached)
31 canister purge ( attached)
32 iac ( attached)
33 egr regulator ( not using)
34 not used
35 speed control vent solenoid ( not using)
36 spark out put (?)
37 power ( attached)
38 not used
39 speed control ground ( not using)
40 power ground ( attached)
41 power and control module two high-speed fuel pump ( attached to ccrm)
42 not used
43 o2 2 ( attached)
44 not used
45 barometric absolute pressure ( attached)
46 signal return (?)
47 throttle position sensor ( attached)
48 sti connector (?)
49 o2 sensor ground ( attached)
50 maf sensor ( attached)
51 speed control vacuum ( not using)
52 not used
53 not used
54 ac cut out relay ( not using)
55 fan control (?)
56 profile ignition pickup ( cam position sensor ? ) ( attached)
57 vehicle power ( attached)
58 fuel inj ( attached)
59 fuel inj ( attached)
60 power ground ( attached)
3 VVS ( attach )
6 VVS- ( attach)
8 not used
17 data link ( ?)
18 octain adj ( ?)
21 IAC ( attached)
24 ckp ( attached)
29 o2 1 ( attached)
32 iac ( attached)
34 not used
38 not used
42 not used
43 o2 2 ( attached)
44 not used
52 not used
53 not used
55 fan control (?)
