PCM stand alone wiring
NovaSS
Project MINIGUN
Im getting ready to start wiring up my festiva / sho project . I have a few questions about PCM wiring. Below is listed what I have so far . A few have question marks next to them. Im not sure of the function , if I need to use it and / or what conditon to jump it in ( open or closed) Feel free to add on or change any thing.
1994 sho MTX based wiring
1 B+ ( battery positive ?)
2 power steering pressure switch ( leave open )
3 VVS ( attach )
4 iginion diaognositc monitor (?)
5 brake on off ( open)
6 VVS- ( attach)
7 ECT -engine coolant temp ( attached)
8 not used
9 MAF return ( attached )
10 a/c clutch ( not using)
11 speed control ( not using )
12 fuel inj ( attached)
13 fuel inj ( attached)
14 fuel inj ( attached)
15 fuel inj ( attached)
16 ign ground ( attached)
17 data link ( ?)
18 octain adj ( ?)
19 fuel pump monitor (?)
20 case ground ( attached)
21 IAC ( attached)
22 low speed fuel pump relay ( attached to ccrm)
23 knock sensor ( attached)
24 ckp ( attached)
25 air charge temp ( attached)
26 referance voltage (?)
27 egr feed back ( not using)
28 speed control command switch ( not using)
29 o2 1 ( attached)
30 clutch pedal ( attached)
31 canister purge ( attached)
32 iac ( attached)
33 egr regulator ( not using)
34 not used
35 speed control vent solenoid ( not using)
36 spark out put (?)
37 power ( attached)
38 not used
39 speed control ground ( not using)
40 power ground ( attached)
41 power and control module two high-speed fuel pump ( attached to ccrm)
42 not used
43 o2 2 ( attached)
44 not used
45 barometric absolute pressure ( attached)
46 signal return (?)
47 throttle position sensor ( attached)
48 sti connector (?)
49 o2 sensor ground ( attached)
50 maf sensor ( attached)
51 speed control vacuum ( not using)
52 not used
53 not used
54 ac cut out relay ( not using)
55 fan control (?)
56 profile ignition pickup ( cam position sensor ? ) ( attached)
57 vehicle power ( attached)
58 fuel inj ( attached)
59 fuel inj ( attached)
60 power ground ( attached)
NovaSS
Project MINIGUN
cool, after I have this all mapped out maybe make this a sticky for anyone wanting to do a stand alone swap?
NovaSS
Project MINIGUN
Well it turns out one of the guys on the Festiva Boards writes tech for Ford !\
He updated the pins
1 B+ ( battery positive ?) correct
2 power steering pressure switch ( leave open ) correct, if not using P/S
3 VSS ( attach ) correct vehicle speed sensor. one of two wire connected to the speed sensor on the transaxle
4 iginion diaognositc monitor (?) connects to pin 12 of the Ignition Control Module
5 brake on off ( leave open) no. connect to brake lamp circuit
6 VSS- ( attached) see pin 3^
7 ECT -engine coolant temp ( attached) correct. other pin of ECT connects to SigRTN (pin 46, signal return)
8 not used correct
9 MAF return ( attached ) correct
10 a/c clutch ( not using) leave open
11 speed control ( not using ) leave open
12 fuel inj ( attached) #3 inj the other pin of all inj goes to pin 24 of the CCRM
13 fuel inj ( attached) #4 inj
14 fuel inj ( attached) #5 inj
15 fuel inj ( attached) #6 inj
16 ign ground ( attached) correct. connects to O/R of CKP, CMP and pin 7 of the Ign Mod
17 data link ( ?) connects to ground side of Check Engine lamp, also the output wire (STO) for the diagnostic connector
18 octain adj ( ?) leave disconnected, unless you have serious spark knock issues, then ground it.
19 fuel pump monitor (?) connects to pin 5 (PK/BK) or the CCRM, which also powers the fuel pump.
20 case ground ( attached) correct
21 IAC ( attached) correct. the other pin connects to pin 24 of CCRM
22 low speed fuel pump relay ( attached to ccrm) correct pin 18 of ccrm
23 knock sensor ( attached) correct. other pin connects to SigRTN, pin 46 of PCM
24 cmp ( attached) camshaft sensor. connect to dark green wire
25 air charge temp ( attached) correct. other pin connects to SigRTN, pin 46
26 referance voltage (?) VREF, reference voltage (+5v) for all sensors
27 egr feed back ( not using) not used on 49-state engines, Calif only
28 speed control command switch ( not using) ok
29 o2 1 ( attached) correct. bank 1, cyl 1, 2, 3
30 clutch pedal ( attached) correct. other pin is connected to pin 46 of PCM
31 canister purge ( attached) correct. other pin connected to pin 24 of ccrm
32 imrc ( attached) Intake Manifold Runner Control. connect to IMRC solenoid. Other pin of solenoid connects to pin 24 or ccrm.
33 egr regulator ( not using) not used on 49-state engines, Calif only
34 not used correct
35 speed control vent solenoid ( not using) ok
36 spark out put (?) Spark Out (SPOUT) connects to pin 5 of Ign Mod, thru a shorting connector (removed to check timing)
37 power ( attached) Ignition power. Must be hot in Start and Run
38 not used correct
39 speed control ground ( not using) ok
40 power ground ( attached) correct. connect to battery negative, not chassis ground
41 power and control module two high-speed fuel pump ( attached to ccrm) correct. pin 18 of ccrm
42 not used correct
43 o2 2 ( attached) correct. bank 2, cyl 4, 5, 6
44 not used correct
45 barometric absolute pressure ( attached) correct
46 signal return (?) also called SigRTN. Computer ground for sensors
47 throttle position sensor ( attached) correct
48 sti connector (?) Self Test Input. Grounded to start code output
49 o2 sensor ground ( attached) correct
50 maf sensor ( attached) correct
51 speed control vacuum ( not using) ok
52 not used correct
53 not used correct
54 ac cut out relay ( not using) ok
55 fan control (?) connect to ccrm pin 14
56 profile ignition pickup ( crank position sensor ) ( attached) correct
57 vehicle power ( attached) Ignition power. Hot in Start or Run
58 fuel inj ( attached) #1 inj
59 fuel inj ( attached) #2 inj
60 power ground ( attached) correct. Battery ground, not chassis ground
White91Plus
Fresno, CA
What does pin 5 provide? Why does the PCM need a brake signal?
