PCM gone crazy ?
91PDXmocha
Portland , Oregon
So last sat driving home from the bank and the car dies, no fuel. No fuel pump prime or whine so I get car towed home. check inertia switch and fuel rail.
cut hole for fuel pump and check pump, with the ecc pin grounded the pump runs with the key on .
next go to ccrm , swap ccrm for another m code and now all that happens when you turn the key the fans come on and you cant check the engine codes.
I checked all the wires and found a rubbed spot in the fusable link from the pos bat cable to the 2 yellow wires feeding the ccrm ? I cut it back and hooked it up directly for now.
I put a meter onto the ground wire coming from the pass side to a plug then to the pass fender and also attached to the bat ground. it was not making good contact so I took the wire out and hooked up directly to it. I also notice here that the ground wire coming from the PCM side has .5 volts on it with the car key off.
now when I got in the car to try and start with the key to on the fans come on but looks like check engine light came on ( not just dim ) But also noticed smoke starting to come from the pcm ground plug I had hooked up. so key off.
with the ccrm unplugged and the ground to the PCM I can read .5 volts on the #5 pin of the ccrm harness and also .5 on pin what 13 that is the FP ground .
Also with the good ccrm plugged in the check engine light stays on ALL THE TIME bright, like even with the key out of the car .
So I have a new fuel pump and ccrm but no new computer. Sounds like my computer is fryed and there is a short to ground somewhere in the engine harness to the PCM ???
Ive read as many old threads as I could find on it and checked everything . Any other ideas before I plug in a new computer and pull the harness ?
Thanks
91PDXmocha
Portland , Oregon
Thanks mike , I did unplug the sensor and have truer tracing all the wires. I'm going to pull the battery and check all the wires again , but I'm worried about plugging in another computer and blowing that one :/ I hate electrical problems .
So I just want to verify . The fuel pump and PCM should not have the .5 volt coming off the ground correct . Pin 5 should be 0 with the key off right ?
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
When I have seen the coolant sensor go out, it keeps the computer/fuel pump from working, but I have not had it blow the computer (just the fuse). If you replaced a fusable link with a hard wire, you may have defeated the fuse function and damaged the computer, but I would try your old computer first to see if it survived.
Mike
91PDXmocha
Portland , Oregon
Put everything back in the car , new ccrm old computer and now the car starts up and will run but within 5 sec or so of having the key turned to on the pcm ground wire and the fuseable link start to smoke . Im going to add a inline fuse on the FL wire . It does this with the fuel pump unplugged and fans unplugged too. Good to know the parts are not all fryed but still bummed .
91PDXmocha
Portland , Oregon
Ok ive found the shorted wire. The white/purple wire that goes into the fusebox #1 and #6 meets the big yellow ignition + wires, is fryed. Going to start ripping it all out and see what I can do to fix it.
91PDXmocha
Portland , Oregon
Well That was one fryed wire fixed that one, and now testing the + battery lead unhooked I traced the ground as far back as the black/org wire coming off the solenoid . It feeds 3 fusible links , blk/org , yellow and black yellow I believe . Looks like they all go into behind the dash . I've started ripping the dash out . Have removed the whole column and most switches . Still grounded out somehere .
Does anyone know where exactly those 3 wires go to next ? I thought yellow goes to ignition switch , no idea on the rest so far .
91PDXmocha
Portland , Oregon
Turbo SHO is alive back on the road. The short is in fuse 8 , interior lamps,stereo and such. I have that disconnected and put everything else back in and she fires right up now wierd stuff no CEL. :) Im gonna find the shorted wire over the next few days while swapping in the black interior :)
thatSHOguy101
