91PDXmocha
So last sat driving home from the bank and the car dies, no fuel. No fuel pump prime or whine so I get car towed home. check inertia switch and fuel rail.
cut hole for fuel pump and check pump, with the ecc pin grounded the pump runs with the key on .
next go to ccrm , swap ccrm for another m code and now all that happens when you turn the key the fans come on and you cant check the engine codes.
I checked all the wires and found a rubbed spot in the fusable link from the pos bat cable to the 2 yellow wires feeding the ccrm ? I cut it back and hooked it up directly for now.
I put a meter onto the ground wire coming from the pass side to a plug then to the pass fender and also attached to the bat ground. it was not making good contact so I took the wire out and hooked up directly to it. I also notice here that the ground wire coming from the PCM side has .5 volts on it with the car key off.
now when I got in the car to try and start with the key to on the fans come on but looks like check engine light came on ( not just dim ) But also noticed smoke starting to come from the pcm ground plug I had hooked up. so key off.
with the ccrm unplugged and the ground to the PCM I can read .5 volts on the #5 pin of the ccrm harness and also .5 on pin what 13 that is the FP ground .
Also with the good ccrm plugged in the check engine light stays on ALL THE TIME bright, like even with the key out of the car .
So I have a new fuel pump and ccrm but no new computer. Sounds like my computer is fryed and there is a short to ground somewhere in the engine harness to the PCM ???
Ive read as many old threads as I could find on it and checked everything . Any other ideas before I plug in a new computer and pull the harness ?
Thanks
Thanks
