Painted Pinstripe - Is it a factory option?
Cheesehead
Schofield, WI
Not a huge fan of the pinstripe on my car. It's not terrible, but would love to remove it. Definitely paint and not vinyl. Any suggestions without ruining my paint job?
Johnbigdog
michigain
Pinstripe is not a factory option.
Its paint on the clear coat so a very delicate polish job should be able to take it off very slowly. I bet a body shop could take it off pretty quick.
Cheesehead
Schofield, WI
Awesome! I was able to scrape a little off with my fingernail so you might be correct
GotGrip?
Conversation Ruiner
Minnesota
Pretty sure that is a stripe kit that was cleared over, you can buy that exact kit on ebay. Assuming it is actually under the paint.
DansSHO
West Valley Arizona
I did have the two pin stripes but Had my them off by body guy yesterday and had no trouble. Mines a 2010 non pp 304b trim level
DansSHO
West Valley Arizona
My car cam from the factory with a pin stripe. The higher trim opt. Had it. I have a 2010 sho non pp my trim level is the 304b the highest trim option and it came with it.
Cheesehead
Schofield, WI
I went to a local body shop that also does detailing and they said it would be very difficult to not screw up the paint underneath. Do you know how they got yours off?
DansSHO
West Valley Arizona
He said a light heat gun and peeling it by hand using his nail where needed. Figuring the cars 10yrs old it came off in pieces and took him longer than he thought.(2 afternoons) After all the pieces where off He buffed it. You can barely tell the car came with the stripe still my need to be buffed more. it’s like it was cleared coated, stripe added them cleared again. He said It wasnt to hard he did it for $40
GotGrip?
Conversation Ruiner
Minnesota
Heatgun/peel works, or if you have an electric drill, get a rubber/gum wheel, it will spin it right off. Just don't hold it in one spot too long, work back n forth. That's what we do here at the bodyshop, works for stripes and the adhesive from nameplates/decals.
Cheesehead
Schofield, WI
Mine is definitely paint so that is a no go. I have used the rubber wheels they work pretty good!
fordfanstan
CA
I used a 3M rubber wheel to remove my SHO factory pinstripes. Worked amazing, and fast.
shoster207
