Finally got the pictures, just as it started to rain...
I used the Avery Nano-Fusion PPF. I had read it was the 'easiest' to put on for 'do-it-yourself'. If that was easy, I'd hate to use something else, ha. It took me about 4 hours and was not 'easy'.
After getting it on, I noticed a defect in the material that goes down the hood and bumper. It is visible if you are really inspecting it. It looks like a thickness change in the material in two pencil width 'lines'. I emailed the company and they offered to replace it, but, I'd have to mark it, then peel it off. I'm debating that option as it would be hours and hours of more work. The camera doesn't really pick it up.
Other than the line, I'm really please with the appearance. You cannot see the material when viewing from the front of the car. You can, however, see the line when viewing from back to front.
Supposedly it will protect the car from chips/wear, but, allow normal paint fade. So, in 5 years or so, I can peel it off and the front should be like new (that's my goal anyway).
It's a lot of work, but, if you want it and have the time, I'd recommend it.
(thumbnail pics attached)
Link to full size images:
https://picasaweb.google.com/markat...&authkey=Gv1sRgCIHhpNXJqYi5Fg&feat=directlink
Mark
