p1414 air pump relay
Troywakeling
Winterport, Maine
Anyone know where someone would get one of those air pump relays that causes this code? Does it have a official name? or just air pump relay?
E1 v2
crash tested
holiday inn
Secondary Air Injection pump is what I've usually heard it called. I've heard some use the term Thermactor pump too. It is mounted to the subframe beneath the battery.
The relay is mounted on the side of the pump and it is a ***** to get at - not like pulling a fuse. AFAIK it is a dealer item. Rockauto.com or NAPA might have something, I've never looked there, just ponied up about $100.00 at the dealer when I want to pass emissions.
Actually if you wanted to go cheap any 40A relay would work. Just need to rewire things.
Fahrzeug
Rent this space
Ashburn, VA
I had to pay the same for the relay from the dealer, PLUS my pump was bad and that set me back about 135.00 with my wholesale discount. Once I replaced the relay, another code set (I can't remember which one off the top of my head) that indicated that the secondary air pump was not operating at all. At least once you get those taken care of, you should not have to worry about them for a long time. :cool:
