p0412 code
ThatShoGuy
michigan
well i been getting this code for a little while...
so i decided to look into it and found the fuse was blown so i changed it with what i had 40amp. popped that one also. so i guessing the pump is frozen.
can i remove the whole system and just deal with the ses(or wait for a tune) or would it cause issues?
It has no affect on engine performance. I would just leave it or remove the entire thing. If removing it you need to fab up some plugs for the exhaust manifold. I just cut off the male flare part flush with the hex and tapped the hole for 1/2-13 bolt then plugged it with one of that.
Removing all the piping cleans up the engine compartment well.
ThatShoGuy
michigan
thats sounds like somthing im gonna put on the back burner for the time. im workin on my tbird sc tryin for 350hp to the wheels. omost there!
