frosho
WOLFMAN
Rear brake problems are quite common. If they haven't been touched in a while, the rubber hoses can slowly collapse internally and block flow back from the caliper. The parking/e-brake cables can deteriorate and get stuck inside the sleeves they run in too, which keeps some pressure on the calipers.
Also, now that I think about it, I think the reason I had such a hard time with my rear o2 is 'cause it's a northern car and everything is corroded or seized. I kept on rounding the hex with the special socket because the slit down the side allowed it to flex some. A hose clamp fixed the problem though.
