overspray on windows
black93sho
Ohio
How do you get paint overspray off of windows. Any help is greatly appreciated!!
yamahaSHO
E85 whore
Arkansas
If you don't know what you are doing, it can. Hold the blade square on the window. Use a 45 degree angle or tighter and you'll be okay. This is the preferred way to remove stickers on windows too.
SASHO91
Zoom Zoom
San Antonio,TX
A Hammer.... :D :bonk:
I know that the orange pumice hand cleaner works really well. but Along with any chemical, there comes a lot of scrubbing.
Sho_Freak
^^ Awesome!
Iowa
just put some paint thinner on a rag and wipe it off.........worked for me when i redid my black trim things.
SASHO91
Zoom Zoom
San Antonio,TX
I havent tried etching my windows yet... but i will take your word on that Jason. i dont think i have the nerve to do that.
allthough i did have enough nerve to take off the side pinstripe with a razor. :eek: that was fun......
yamahaSHO
E85 whore
Arkansas
You'd really have to screw up to really scratch the window... I've done it MANY times on my cars to remove crap. You'd have to have a bad blade or dig the corner in to mess it up.
rangerj
Brunswick, Ohio
Use a single edged razor blade with a fresh sharp blade. I think you can fing a thing called a widget at K-Mart or Wall Mart for about a $1.50. It has a few single edged razor blades in a handle and it is made, more or less, for scraping paint off of glass.
As stated above scrape at about a 45 degree angle. A dull blade is far more likely to scratch the window than a sharp one.
If the paint is fresh I would not get anywhere near it with paint thinner. rangerj
jelloslug
Digital
Greenville, SC
I had a ton of overspray on mine, I used one of those Scotchbrite pads that are made to clean glass cook tops on stoves. It was much faster than scraping and scraping and scraping and scraping and scraping.....
3.8Lwagon
Shaggen Wagon
use a new sharp razer blade. u will not scrach the glass. and it take sno time to remove over spray/ stickers
TimboSHO
Intermediate
Wyoming, MI
A razor blade will work just fine. With fresh paint, it should come off like nothing. It's really difficult to scratch glass.... i haven't done it yet and i've used a blade alot!
stangconcepts
arkansas
Yes a razor blade will work fine I have been doing it for 15 years and have yet to scratch the glass. :cool:
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Acetone or denatured alcohol on a rag. It worked wonders on my 92 when it was someones "artwork"
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Acetone, denatured alcohol, or paint thinner work much faster...
yamahaSHO
E85 whore
Arkansas
Not in my experience.... Go over an area just once with a blade and the paint is gone. No wiping or scrubbing.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
I had racing stripes on the front and rear windows that I started to use the 'blade on. I poured the 'alcohol on it and wiped it right off instead. No paint shavings left over either...just toss the rag once you are done with it.
DHMag
Free At Last
InCahoots, Texas
overspray vs intentional painting. overspray is the topic, razor blade is the quick and easiest way.
for me, its faster to slide the razor blade over the glass than open a can of acetone or thinner, apply to a rag, then rub back and forth for several strokes.
use a razor blade to clean, then compressed air to remove the scrapings.
use thinner/acetone/other chemical, have to watch your coverage to insure you dont mess up the purdy paint job.
