pitaSHO
Why do I do this to myself?
Are they worth it? I did some poking around on RCM and noticed that the oversized valves are only one mm larger than that stock size. Are they worth it? The motor will eventually get boost, but that's a ways away. My long range plans for the motor would include:
Low comp pistons
pnp heads
Over sized valves and brass valve guids (maybe)
Tri-flow cams (interference motor?)
Turbo (eventually)
I know I could just boost a stock motor, but I just have the bug to build one. I'm in no hurry and will only do what I can afford, so it could take a while. Any feedback would be appreciated.
Thanks.
Chris K.
Low comp pistons
pnp heads
Turbo (eventually)
Thanks.
Chris K.
