Overriding the Moonroof switch?
SHOfun 93
Euless, Tx (Fort Worth)
I tried to get the moonroof closed today during a rainstorm to no avail. I took apart the moonroof switch and after removing the plastic part, how in the **** do you contact the little black part to something up there to "activate" the switch to allow me to "trick" the roof into closing?
Also..does anyone have a writeup/way to use a window switch in leiu of that crappy ford switch? I sure as **** ain't paying $50 to the dealer for another switch that will break in a month.. headbang
<small>[ September 25, 2003, 10:53 PM: Message edited by: SHOfun 93 ]</small>
Bank of SHO
Vegas
Do a search for "moonfoof problem". Yes it is misspelled. Your fix lies within.
I don't know how to close it manually.
Bank of SHO
Vegas
The oem switch is a joke. You could try to use a small screwdriver near the pivot point of the switch. Look at the broken part. That's where it would contact the tiny microswitch. Do this at your own risk. I have no idea if it is wrongheaded.
SHOfun 93
I have tried to "trick" it into closing by contacting the black part onto the metal tab attached to the roof. Lotsa sparks, no luck...
Does that little tab just contact the rear of the black switchbox? I might have a burned up motor, perhaps? I dunno... shrug
