outer cv boot
brandon_oma#692
can i replace the outer cv boot without removing the axle? I ripped a 3/8" slit in it when changing wheel bearings and dont want to take it further apart than i need to. Or is this something i can patch?
SHObill
'The Collector'
Rochester MI-48307Detroit
Oh come on! Don't have to be SO proper! It's a 15-20 yr old Taurus!! LOL Both my outer boots were split & I just moved the inner half of da boot into the outer half, added some grease & all was good for a year. They never even threw out much, & what little did come out helped protect stuff down under from MI weather. Guess it would matter where the split was though.
brandon_oma#692
are the "quickboots" tha glue or screw together any good? I found a glue together one at oreillys or autozone that seems to be dimensoinally correct.
FrakensteinSHO
Abused SHO
Minnesota
If your not driving it anywhere then a new boot will work. But if your driving it around you might as well get a new axle due to the dirt and crime already in there.
Phoenix
SHOHOLIC
QC , Canada
It gives a nice anti-rust inside the wheels and on the knuckles.... My front left side as a nice coating.
38SHO
#1 Oil Abuser
North Palm Beach
one point to add here, being someone who put new proper boots on my axles the way your supposed to.... if you don't want to pull an axle and find that daunting..... changing the boots on an axle is going to kick your ass.....
so either just get a new axle or bite the bullet and fix it correctly, you can get the right axle boot from rockauto.com
don't half ass it
SHObill
'The Collector'
I agree with 38! If your going to pull a half shaft, may as well replace it. I had boot kits & pulled them but could not find a way to remove the bearing assy to slide em on so just put new ABS halfshafts on an 89 that I wanted to save for an ABS car! Its easier to just replace.
brandon_oma#692
what is a half shaft going to cost? I heard i can mess something in the diff then i am in real trouble to fix it.
crystizel
