ouch!
munkee
Too busy...
Missoula, MT
The stabilizer bar link on the driver side is bent on my 90 mtx. I assume thats why the inside of that tire wears out faster and when you are driving straight and try to turn left, the wheel is hard to turn until a noticeable bump after which it turns normally? Is the part the same from a slo model car the same? ( I have a parts car already )If so, are the boots also reusable or do you have to get new ones?
"It's not just the speed, it's how well you handle it."
There was a production change to a composite (plastic) link with more durable joint bellows. You can get this link through Ford or the on-line parts and SHO vendors. SHO NUT has it for about $50.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, Alum SFB, SS front/rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
S
slosho
Guest
Autozone has sway bar end links for $19.99 each.
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" lines
Lighting mods
Convinience mods
More to come.
