Options for Strut Mount/Camber Plates?
vortex2450
Buying Parts...
North Carolina
A while ago when I took my SHO to get aligned I got a perplexed look from both shops and they told me they could not adjust my camber at all. Right now it sits somewhere in the -2 degree range for both front wheels.
The spots welds are broken so I do not understand the issue here. The car is riding on Eibachs/Tokicos and it's not lowered very far past stock height.
Compounding onto this I believe my strut mounts are in need of replacement. The right side makes a rubbing/clunking sound when I turn the wheels right.
So I am curious what my options are? I want to replace the strut mounts and be able to further adjust my camber.
Will these for SHOSource work and allow enough positive adjustment to pull from -2 camber?
Thanks
-Josh
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
If your spot welds are already broken, I think you need to find a better shop. As for mount options, Ingalls and Moog are your only 2 options for adjustable mounts.
zach44102
BIG TURBO
Georgia
I have the Ingalls mounts and setting the camber/caster was a breeze. Nice product for the money.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Thanks
-Josh
The Ingalls mounts shouldm be enough to get you into tolerance.
