One of my sfbs just spins
llamaking122
Green Machine
Columbus, Ohio
so i noticed that i was having steering problems. the wheel would get hung up. but when it did i would fell something in the clutch/brake/etc. so i check my sfb all off them got tigheted with a 3foot long breaker bar. but the one near the airbox just spins it looks like a nut on the bolt how do i tighten this one down?
SHObill
'The Collector'
Rochester MI-48307Detroit
Are you trying to say that one of driver side SubFrame Bolts just spin? IF its a rear you can go in thru the recall hole inside with a wrench & hold the nut as the tabs that hold the plate/nut from spinning have broken off. If its a front there is much more to remove to get to the hole in the SubFrame to hold the nutplate.
--please use spell check & more periods please!--
SHObill
'The Collector'
On the inside of the subframe there is a square hole to access the nut. You must move/remove the ABS pump & horn brkt to see it. OR cut a hole on the outside!
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Bill... maybe you might cut a hole.. but I wouldn't tell anyone to just make a hole.. :) Hate to see someone cut a big hole, or in a bad spot and have a problem later on.. :)
I'm pretty sure with a 15, 17 maybe wrench , (closed / offset end) should grab it. If that dosent work.. I can't remember but a Craftsman might not fit.. might need a snap on if you know someone with them.. they're a little thinner.
Otherwise you'll need an impact... and put antiseize all over that damn thing, it'll help thread it, and be nice to unthread it when you take it off. ;)
NEp8ntballer
cyber ninja
fifth circle of ****
or just remove the inner fender liner and tire one whatever side they are working on... unless my car has holes in the body that aren't supposed to be there, which wouldn't surprise me.
93rev2sev
Hockeytown
Eric, I think that only works when you have subfame recall nuts up front...the ORIGINAL subframe nuts require that you get in there if the tabs are broken.
NEpaintballer, It sounds like you have holes that weren't there originally. On the Driver's side, cutting a hole on the outside is the only way to save an original subframe nut without taking considerable risk that you will damage the 15-20 year old Anti-lock brake lines.
To the OP, You have a dilema. The correct way to fix this issue is to replace the bushing(s). I'm fairly sure that even if you CAN get a wrench on the old subframe nut, you won't be able to get it any tighter. Original front subframe bushings do not "squeeze" the subframe.
ohioshodude
SHO'ld fogy
delaware, ohio
torch.. out in 2 mins. had to do that on my 93. front passenger just spun. had my uncle come down with his torch and he had it out in less then 2 minutes.
llamaking122
Green Machine
Columbus, Ohio
do you have a tourch? i live in an appt so i dont have the full amount off tools i could. and if i do we dunno where they are
jmpSHO
Massachusetts
If you let the sub frame hang down a little and put pressure on the nut you might be able to tighten it.
Brad kirk
