nc89sho
S13 Sellout
to start off, let me say that i am an auto tech. so i know how to repair/bleed brakes, but this one has got me stumped and i'm starting to have thoughts of parting this car out and that's not good. first off this is my current brake setup:
'96 front, 89 rear brakes. stainless steel hoses.
here is the rundown of my situation:
i was bleeding my brakes by myself. (not because i had a problem, just as a preventative messure because i race this car and the brakes get hot.) I was using speed bleaders and after cracking the first rear bleeder screw loose, the brake pedal got crappy. i finished the bleed sequence and after closing the final screw went to check. I had NO brake pedal at all. (brake pedal was high and firm before this. After getting someone to help me, i blead the whole car the manual way and found that one of the rear screws kept emiting air nomatter what. after carefull examination i determined that the bleeder screws were allowing air back in (possibly past the threads.) so.. I went and bought a set of 4 bleeder screws and replaced all of them. after a few more minutes of bleeding all 4 were giving me nothing but fluid. so i go check and the pedal is firm.... Untill i crank the car. with the car running the brake pedal is very spongy and moves over an inch before REALLY feeling the car slow down. if you pushed hard enough it would go past the gass pedal by about an inch. So i continued bleeding, stoped drove it some. blead, wait a couple days blead it again and so on. with NO change in pedal travel.
SO, .. i decide to try changing the master cylinder. can't find one with the 89 configuration of 1 M12 fitting and 3 M10 fittings so i opt for one listed for an SHO at advance wich has 2 M12 fittings and 2 M10 fittins. it was pretty easy to cut off the flare, swap an m12 off the parts car, and bolt everything up. i blead everything out and wound up with the exact same pedal feel.
So i decide just to take them out of the mix (and because a new season is coming up) I replaced the front and rear brake pads, and re adjusted the parking brake cable. Then got ahold of a power brake bleeder and attached it to the master cylinder and after bleeding it in the sequence alldata called for (LR, RF, RR, LF) i seemed to get a small bit of air out. pedal felt better for a couple minutes but after a short trip down the road, the pedal feels EXACTLY the same again.
I'm at a loss..... forgot to mention that this is acctually the third master cylinder i swapped because i thought maybe the second one was defective.
what am i not checking???? is this just the brake system that will never be right again?
oh, and the car still stops, brakes work, just not like they used to, the pedal was never this spongy and non-responsive before.
