ONE fast blinker...
DavidT
TN
the right turn signal blinks ultra fast (must be the additive I added to the blinking fluid) :p
I recently had a new multifunction switch put in under warranty. It started doing this sometime later. Is it related?
masho95
got Zex?
Chicopee, MA
A fast blinker on one side indicates that you have a lamp out on that side of the car. Could be a turn signal light, head light, etc.
DavidT
TN
:doh:
I forgot to mention that I checked those... everything SEEMS to be in order...
SHO#7
Cincinnati
Sounds like a flasher. I am sure someone will chime in, to tell you where it would be located. I have never had to replace one yet. I would follow the click noise that it makes. I may be wrong, but have had the same problem on other cars. And the flasher corrected the problem. Good luck.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
If its your blinker flashing fast, its almost always the actual turn signal (on the corresponding side) or it could the light on the side that comes on with the turn signal also. Make sure to check front and rear.
Glue Maker
The V8 Paradox
Sugar Land, TX
Did you also check the side yellow marker? It and the front signal blink alternating. (Just incase you didn’t know)
coyote
ar
Blinker problems as well
I just read a couple of your posts. The one about the antenae and the one about the blinker. I have a 97SHO and just yesterday I noticed my antenae would not go down. Then this morning my blinkers just quit working. I have checked the fuses and they seem alright I did notice the front driver side light is burnt so I guess i will replace it and see if that helps. Could the two problems be related? Anyone have any ideas how to correct?
DavidT
TN
coyote,
my blinkers stopped on me and my headlights stopped too. It was the multifunction switch.
I found a brand new antenna mast on ebay for around $20... check out ebay :thumb:
