tery
Silvia survived the purge- summer car
It turns out that someone put on an air compressor bypass kit that doesn't quite fit right. That's why the serp belt was kinda torn up. Has anyone had experience with using one of those bypass kits? Is it a reasonable fix to use when you can't/ don't want to replace the compressor? I guess what I'm asking is...should the correct kit work properly and be able to line up right so the belt path is good? Seems the one on there either isn't the right one or isn't put on right or maybe is missing a shim or something cause the path isn't right with the new belt...yet!!
T
T
