Ok.. I got my heads back.... few questions..
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I'm going with the numbers... 36-51 lbs, then 62-69 lbs. I have a copy of the pattern, just wanted to double check the numbers.
Also... it says in the haynes to lightly oil the bolts. Don't I have to adjust those numbers 1/3 for that? Or are they taking that into account? I'm going to lay them up there, and get a few pics up. Hopefully someone can tell me what they do when they replace their heads. :wave: :salute:
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Ok.. now my next question.. which side of these head gaskets is up? I didnt see any writing on it anywhere. And only noticed one small difference.
One side...
P1000483
P1000479
The flip side....
P1000482
P1000481
Just curious which side is the 'top' first set of pics or second? Thanks!
Intake and exhaust side of the front head.. other still in the bag..
P1000486
P1000484
SHOtimer
#2910
Santa Clarita, Ca
The gaskets will only line up with the head and the block - with proper orientation to the holes in one way.
Are those new heads or reworked heads?
Doug
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Hey thanks! I did notice that one extra hole after I got it set on the block. I did get it all figured out, just wish that one wasnt so close to the cam. Its almost like you need a LONG tip on the end. Almost thought I was going to have to loosen the cam. Glad I didnt.. enough wiggling and it was good.. here's some more pics.
And they are reworked. Been degreased, new valve seals, guides checked out fine. Had the valves re-seated, installed 2 (newer but used) Chain tensioners, pressure tested, and as they said, good by the factory standards. More pics of the progress..
P1000497
P1000505
P1000508
P1000510
yamahaSHO
E85 whore
Arkansas
Anytime you take a torque reading, the bolts/nuts should be lightly oiled.
SHOtimer
#2910
Santa Clarita, Ca
When I installed my heads on my new 3.2 I did it before I installed the cams - didn't want to mess with them being in the way.
Also, just as Jason said, lightly oiling the bolts allows a true torque reading.
Doug
93rev2sev
Hockeytown
Hey Eric, thats starting to look like an engine...looks great man. You've gone a lot further than I have so far. But I did buy a SHO since starting my rebuild. :thumb:
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
LOL... now you just added to your workload I take it.
Only thing I cant seem to figure out where they went to, are those stupid timing cover bolts. Guess I'll be out getting some of those here soon. Well she's all timed, and the big part of the front end is on. Exhaust comes tommorow, a few mounts, and I think I'm going to drop her back into place.
P1000516
P1000514
1993MTXSHO
Its a Taurus...
Jersey
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Just the height from the top of the cap to the bottom of the threads. It screws in tight, just dosen't ''bottom out'' the threads. Hope that makes more sence. I"ll get some pics up soon.
I will say this tho... after bolting on the front, I stood back and looked, and heard a crack of lightning. In Feburary!! A sign of things to come? LoL almost like outta frankenstein or something. :)
platoribs
Live to Drive
Plat0ribs House of SHO,il
:lol:
Its ALIVE:eek:
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
LoL... that means I bought a bunch of stuff from you I don't need anymore.. :) I will honestly say tho, I always enjoyed driving the V-6's, but that sound of the V-8's with a nice exhaust is starting to test my patience. I can tell you that after my woman ditches the Malibu, I hope to talk her into a 99 if I can find a nice one to work on. :) Just don't go anywhere anytime soon, maybe for enough stuff I'd just drive up there and pick it up. :) I'm just glad THIS money pit is almost complete!
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I also just realized 2 brackets I didnt paint yet.. grr.. lol hiding under the timing cover and a towel.. lol Then its on to finding those bolts I misplaced.. lol doh!
1993MTXSHO
Its a Taurus...
Jersey
do you mean the cap doesn't sit flat against the valve cover because the threads are to long? Or the threads arnt as long as the stock cap so it just doesn't screw in as far.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
It bottoms out. They are too long, but it seems to hold fluid out.. filled it with water and turned it upside down.. nothing came out.. so it might be ok. Wont know for sure until its on and running.
nik97
Mile high
midnightauto said:
that engine looks pretty good, But shouldn't it have 8 cylinders?
Sir, you have a very nice 3.4 there:thumb: Makes me miss my '97.
