OK, I can not pull codes????
Fusion
Dayton, OH
Not sure on this one. I followed the instructions form Mr. Anonymous links in his sig and nothing. I even went so far as to make sure the battery has a full charge. Jumper wire in, no "check engine" blinking. Tried a test light from PIN 4 and no dice. Any ideas??? shrug
40BelowSummer
Puerto Rico
make sure you have the right pins jumpered. when i did it i had the connector upside down compared to the pic. sometimes its the simplest things oh
projectSHO89
SHOless In St L
Fusion:
More specific information and troubleshooting is needed.
The CEL should be lit as soon as the key if turned to RUN before the engine is started. Does yours come on?
What exactly are you referring to - "Pin 4"?
Steve
Fusion
Dayton, OH
I did it EXACTLY as shown in this Pic,
The CEL will light up breifly when I flip the key, so I know it is not burned out.
No Car does not start, read about it here.
http://www.shoforum.com/ubb/ultimatebb.php?ubb=get_topic;f=49;t=000013
<small>[ March 09, 2004, 08:39 AM: Message edited by: Fusion ]</small>
Fusion
Dayton, OH
guitar333:
Good Call, I feel Dumb
I pulled a 114 and a 116.
114 is a air charge temp sensor, this is the sensor in the air box right? I do not belive this is the problem.
116, Looking at the codes page, there is no code for a 116, just my luck :rolleyes:
http://www.shotimes.com/php-bin/modules.php?op=modload&name=News&file=article&mode=thread&order=0&thold=0&sid=84
Fusion
Dayton, OH
OK, Found it on another link
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
114 (O,R) IAT sensor out of range - IAT
I really do not belive that these woul be causing my problems
projectSHO89
SHOless In St L
Fusion:
114 - If colder than 50 F ambient, ignore.
116 - If engine is not at operating temperature, ignore.
Did you ever get this thing to start? If not, just ignore both of those codes.
Steve
