oil pump removal help
oneqwicksho
cleveland, ohio
i am going to be pulling the oil pump off a spare motor i have and was wonder if anyone has basic directions on how to remove/install the pump
thanks
Devin
3.Slow
Pacific Northwest
Take off crank bolt
Pull off crank pulley (with puller)
Remove timing belt retention washer
Pull off timing belt sprocket (don't remember if this requires a puller)
Remove crank position sensor (CKS)
Remove bolts from lower timing belt cover and the cover itself
Remove oil pump bolts, then oil pump
