Oil Pressure???
SHODOGG
Crowd Control
SHOCAGO
Hey guys, Im concerned that my oil pressure is too low on my SHO and I might need to think about replacing my rod bearings. Where should my oil pressure be at at idle?? Mine seriously is about 15psi maybe if not less. Help!!
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
15 is EXCELLENT.
The SHO uses a high volume, low PSI oiling system.
And Id never worry about it, unless it dipped below 10PSI.
FYI, the low oi PSI sensor trips the red oil lamp at 6PSI.
DHMag
Free At Last
InCahoots, Texas
10psi per 1000RPMs is an acceptable limit. mine was 15-20psi at idle all the time.
in other words, youre fine.
