My cruising hot oil pressure runs about the same as yours....usually about 5 psi higher than the rpm k's....like at 2500 rpm, I run about 30 psi.
This is on an AutoMeter mechanical gauge, hooked up through a T fitting along with the idiot light sensor......it reads a little lower than the old SunPro gauge I used to have, but I trust the AutoMeter more. For oil, I run Castrol GTX 10W30, with a Motorcraft FL-1 filter.
I have replaced the rod bearings, and done all 60k maintenance. With the exception of a bit of timing chain slap on the front head, my engine is seemingly entirely healthy....although my oil pressure does seem a little lower than ideal. I don't really worry about it too much tho.
