Oil pan removal
LaX SHO
La Crosse, WI
I am currently in the process of replacing the oil pan seals on my SHO. I have the oil pan pryed loose but the pan doesn't seem to want to clear the motor mount to drop all the way out. I tried angling it every which way. What is the trick to getting it out?
EDIT: Nevermind. I just got it. I guess I just needed a break or something. :bonk:
kevingotashotoo
200 or so ponies
peterborough,ON canada
while youve got it off, throw on a temperature gauge:thumb:
Ishodu
Make sure you do a few dry practice runs getting it back up there. This way you don't mess up the RTV when installing it.
Howdy_Doody
Chesterfield, MO
Are you replacing your oil pan seals to stop a leak? If so, I'd be curious to find out if it was sucessful. Mine is leaking all over the bottom end and I'm not sure if it's front or rear seals or the oil pan gaskets.
LaX SHO
La Crosse, WI
Well I'm actually selling the SHO so I won't know if it worked or not. I was told that it was the problem when I had my clutch replaced.
