Robert Housley
- Joined
- Jul 12, 2015
- Messages
- 7
- Reaction score
- 0
Just swapped an 89 3.0 into my 92. The motor sat for 15 years with oil in the pan but no coolant. This motor had 96k at the time the body was killed. I replaced the water pump, valve cover gaskets, belts, hoses and such. I had some leaks at the intake, so I bought new gaskets. I decided to change the oil in case of crap from leaking intake. When I pulled the drain plug I got about half a gallon of straight, green, uncloudy coolant before the bad goo came out. I am trying to figure out if it is possible for the throttle body to be dumping coolant directly into the crank case vent hose. It is like I unscrewed the oil fill cap and just poured the coolant in. Any advice or even an educated guess? I have another motor, but I really don't want to switch motors if I am just missing something else...
Thanks,
Robert
Thanks,
Robert
