oil light under idle bad?
shobote
Naperville, IL
Replace the pressure sending unit; $5 and 5 minutes to swap out and if the light goes out, call it a day; if you don't hear any rod knocks on cold startup, I would not worry about doing bearings right away since it is winter and is a DD.
itwonder
VA
I'd change the oil light sensor, they can deteriorate with age. ... 50K.
Ditto. An old oil light sensor can also leak, which makes a big mess. Replacing it is easy $5 preventative maintenance.
38SHO
#1 Oil Abuser
North Palm Beach
well I did hear some rod knocks on it when I first bought the car, maybe the first three times I started it... since then nothing
he said the car was sitting for a year
I gotta drive it haha, the temptation is just too much to take it out for a few minutes here and there
I'll be changing the bearings saturday, I got em for 48 bucks or such from a local speed shop........
hawkeye18
Sorta cares
Norfolk, VA
yeah, when the SHO sits for more than a month or so you really need to crank it for a little while to let that oil circulate and build up some pressure... the easiest way to do this is pop one of the ends of the DIS off and crank it for about 10-15 seconds. Then, plug the DIS back in and yer good to go. This also gets the valvetrain, etc, coated in oil. You would not believe how much an engine can wear in the 3 seconds it starts without oil.
But I will +1 on the oil sensor. They, like all other sensors, do go bad.
cetroutt
troll
SEMO
i'm thinknig of doing bearings. is this something you can do with engine in?
Storm-Chaser
Shit Louis
Did you get Clevite rod bearings for $48 total - that's an very good price, especially for a local speed shop.
38SHO
#1 Oil Abuser
North Palm Beach
yeah, I got it through a company my brother's wife works for that has an account with that shop... so I guess they get a discount or such(they specialize in a lot of older/musclecars)... gotta wait 2 days for the bearings tho
itwonder
VA
Remember to order a Felpro oil pan gasket set. Those can take a couple of days to get. And you'll need black sensor safe RTV.
poffffd
