Oil Light On
Silver95
Niagara Region,Canada
I searched the forum and it seems to me that it might be the rod bearings? It is not the red one, but the yellow light. Any other possible ideas as to what it may be? The car has not 'really" been driven for almost a month.
About the rod bearings....what are they? what do they do? where are they located? how hard is it to replace them?
As you can tell i have NO CLUE as to what these rod bearings are, but i heard the words often on here.
thanks a lot guys,
Marko
Ishodu
They Yellow light is a level sensor! Check your oil!. If its ok the wire may be off, or you could need a new sensor.
ckinart
Mississauga, Ontario
Rod Bearing Info
Marko,
Even though it sounds like your problem is likely not worn rod bearings, I thought I'd give you some info to help you understand the questions you've posed about them (rod bearings are a popular subject on this forum). Have a look here for some basic info on internal combustion engines (note that the diagram depicts a SOHC engine versus your DOHC). Item "O" in the diagram on that page labels the rod bearings which are basically thin, semi-circular pieces of metal about an inch wide that surround the interface between the connecting rod and the crank shaft (one half on the top, the other on the bottom). As the engine operates, the connecting rod is shoved down and then pushed up, and the rod bearings sustain (provide a wear surface for) the rotating loads on the crankshaft from the connecting rod -- I think that's clear. There is one pair of rod bearings for each cylinder, so your 6 cylinder engine has 6 pairs of bearings. Have a look here for info on how to change the bearings, and some good pictures of the bearings themselves.
From my experience, it seems that the rod bearings are probably the weakest link in the V6 Yamaha SHO motor (mechanically), and as more and more miles are clocked on them, more forum members are either forced to change theirs, or replace them as a precaution (as I did). As others have said numerous times, it's "cheap insurance".
Anyway, I hope this clears a few things up for you! :thumb:
Silver95
thanks guys,
i dont think it is the rod bearings either, but my "check oil" light still comes on as soon as you start the car and it stays on.
CheckerSHO
Ford Employee
Acworth, GA
Silver95 said:
thanks guys,
I think it's trying to tell you something :thumb:
If the oil level is full then the wire is shorted to ground somewhere, or the sensor is bad.
Silver95
yea its one of the two for sure. Man these cars **** me off sometimes. always this and that, and on top of it, they were not cheap when you bought them new.
