Oil Level Sender
SHO92
Upper Freehold, NJ
Is there some way to disassemble the sender to remove it from the harness? The wire on the sender I have now it currently melted to the pan, so it needs to be replaced. I have a good used one, but the wire is starting to fray and its soaked in oil.
Is there a way to disassemble it? I see that the large nut has a split in it near the top like it might seperate and unsrew. I tried unscrewing it, but no luck so far. The black plastic boot doesn't appear to unscrew either.
Any input?? Thanks...
Gez89SHO
LEGO SHO
NE Philadelphia, PA
I've replaced this before, there is a way to remove just the wire. You see the split in the large nut? That's where the wire clips onto, there's a square clip in there, looks kinda like this []. Remove the clip and the wire pulls straight out. You can then unbolt the sender if needed (drain the oil first though).
BTW, how are you guys in Jersey? Been a while...
