SaltyDog
After a ~2 year hiatus, I am a SHO owner again. :woo-hoo:
The new project is a '91 SHO+. My question for the group is about the oil pump cover. I surfed through previous threads, but I didn't quite find the answers.
I have a big leak coming from the passenger-forward side of the engine. I'm still disassembling things to get a better look, but I am pretty certain this is NOT coming from the valve covers/cam seal area. The crank seal by the lower timing gear appears to be good (no visible leakage).
Data point - as I was removing the idler pulley assembly (the one on the forward side of the engine, near the alternator) the bottom bolt came out of the block soaked with oil. I checked...the hole in which it belongs is filled with oil. What might cause that? That never happened on my previous SHO.
I have more work to do - pulling the pan this week and after that, I intend to pull the timing cover and re-seal it.
Anyone else pulled the timing cover? I'm interested in any/all advice from anyone who may have seen/done this before.
If/when I get a better site-picture on my dilemma, I will post info/pics.
Many thanks in advance!
Brian
Brian
