Oil Cooler Gaskets
K-Dawg
Treasure Coast, FL
I can't get a definitive answer in the other thread, so I'll ask here. :corn:
What will I have to do to seal the oil cooler after I put it back on? Can I get the gasket(s) anywhere? Can I make my own? I have yet to take it off the block, but it will probably happen tomorrow, so I need to know soon. Thanks.
Yamaha V6
SHO Enthusiast
Rhode Island
As mentioned, apparently Fel-Pro has an oil cooler gasket kit.
There are 2 gaskets - one large dia (about the size of the oil filter), and a smaller dia one for the bolt that runs through the middle of it.
Get a bad seal in there, and you're looking at a potential catastrophic coolant / oil mixture.
K-Dawg
Treasure Coast, FL
You said you have one of the gaskets? Want to part with it?
I looked for the Fel-Pro set; couldn't find anything.
Yamaha V6
SHO Enthusiast
Rhode Island
I also looked on Fel-Pro's (Federal-Mogul's) website, did not see it. Perhaps it's part of the "Conversion Set", #CS9821?
Off Road SHO
Moderator
Fred, Are you sure those seals separate the oil from the coolant? The larger rubber gasket seals the heat exchanger to the block. The smaller one rides in a pocket that surrounds the transfer tube with the bypass spring and plunger in it. The coolant flows though sealed tubes inside the heat exchanger.
Or am I all wet with hot coolant on this one?
Tom
KentuckySHOoff
Bardstown,KY,
Tom
the larger gasket was torn on mine causing a leak. the smaller one seals the bolt.
DHMag
Free At Last
InCahoots, Texas
both seals are for oil. there is no chance for oil/antifreeze mixing, unless the exchanger itself fails.
Yamaha V6
SHO Enthusiast
Rhode Island
I'd honestly have to take a closer look at it - I thought the bolt one separated, but didn't give it a whole lot of thought.
For the cooler adapter to the block you can make your own or use some silicone gasket maker.
Off Road SHO
Moderator
Paul,
Isn't that a flat o-ring type of gasket? If it is, I wouldn't advise using silicone in its place. I'll go and check right now.
walk walk walk walk....slam
Yamaha V6
SHO Enthusiast
Rhode Island
Tom went out to check, and his polished (everything) flash-blinded him. He's stumbling around the desert now, trying to avoid the Cottonmouths, Scorpions, & Recluses. ;)
Shoaz
Studly dood
Scottsdale, AZ
Yeah, I'm always careful to wear eye protection around that buggy. Looking at it with the ***** eye is ill-advised. :biggrin:
