Frisbeeguy
Oh snap. Something is fried...
Finally decided that today I'd get the car back up on the stands and un-do some stuff to see if I have some sort of pinched power steering line. (I recently replaced the clutch, T/O bearing, and Y pipe and reinforced the MM's) Upon re-assembly the PS pump was WHINING. It didn't do that before.
So put in a new cooler since it seemed to be leaking and then bought another pump from a forum member and put it in - it's even worse.
Unbelievable... when putting on the engine support the big 6" eye bolt was in the front lift ring and it fell directly onto the positive battery terminal - sparks were flying and it fused itself on... had to really yank it hard to get it to release from the battery.
Then ******* me... immediately tried to start the car using the battery charger - reversed the leads and plugged it in - Ackkkkkk.
Any ideas on what to check first? Could it have just fried the battery? A fuse(able link)? Oh man - what an idiot.
Thanks for any help on this...
(it's an '89 btw)
(it's an '89 btw)
